Does ax5 bellhousing use support bracket to engine?
JeepXstreme
Gentry, Arkansas
??? I have a 89 Mj ..doing bell housing swap ..its a 2.5 with ax4 and had the old support bracket for bellhousing to engine mount. Swapped engine mounts out and put in a 2000 2.5 motor.. With x5 bellhousing.. does the ax5 bellhousing use a bracket also that runs to the bellhousing from engine fir support? Please help. Thanks.
I have that setup .. replaced with 2000 brackets and engine.. so ? Is does the 2000 2.5 engine need a brace to the ax5 manual 5spd bellhousing? Thabks fir the reply tho.
