- Maurertown,Va.
CB or hand held,s. My Bafeong (sp) needs programmed.
How are you mounting them? I only found this: http://www.stinkyfab.com/baofeng-rugged-handheld-radio-brackets.html
I like my CB because I have a tiny external speaker that I can hear really well. Even with a helmet on.
I clip mine to the visor unless stuff gets interesting then it rides in the cupholder or the copilot holds it. You can get a lapel mic to clip on your shirt if you're worried about hearing it.
That bracket is nice though.
Do you wear your helmet at all times, because I am pretty sure you never listen........
I don't understand. I'd have to see this I'm a visual person.You can weld a 1/4-20 nut on to the back of some steel plate and screw a ram mount ball into it and then the mounting options are endless.
I don't think you not understanding has anything to do with your eyes
You get one of these:
http://www.rammount.com/part/RAM-B-273-1U
Then you weld one of these to the back of some 1/8 plate steel, cut to the size you want:
https://www.fastenal.com/products/details/0147964
Screw the ball into the nut.
Then you can use any 1" ball mount from your favorite online retail store, suction cup to the windshield, screw it to the dash, use a rollbar clamp on a cage.
The radio clips on the plate.
Need to draw it up mounted to is helmet for him......
Not sure what the helmet is for, the jeep never moves.
