Cherokeefever
- Bonney Lake
Well we needed an new tread so here it is.
Well i finally got my onboard air hooked up
Found out the 3 bolts that hold the mount to the block for the pass side motor mount where snaped off!!!!! :flame:
My oil filter is dented to hell.
My motor is resting on the fender....:smsoap:
This happened to me 3 times until I installed a set of MORE motor mounts. Hasn't happened since. One time I had to have a bolt extraction expert (yes there is such a thing), to extract one of the bolts cause I couldn't get it out of the block. My advise, put some after market motor mounts in it now rather then waiting for it to happen again.
I finally put mud flaps on my jeep! lol now i know the cops are just messing with me if i get pulled over... Cherokeefever, what size fittings did you use to hook your airlines to the ac pump? Is that orange part a water air seperator or an atuomatic tool oiler?
The whole jeep?Covered it in silicone hoping to stop the leak.
X2, minus the gas part.Put gas in it... drove it... came home... lol
