RWKHausSupply
- yorba linda, Cali
Just released...
Curries all new Rockjock Dana 44 housings.
These are very similar to the D60 just without the rotated cover. There was just not enough room to do so with a D44.
These are designed for the JK larger reverse cut Gear Set. This gear set is larger then the typical D44 and noted to be noticeably stronger then the typ hpD44.
The center is thicker with much better oiling then the stock JK center also.
From my Site....
The Currie RockJock® high pinion 44 is an all new, heavy duty 44 made 100% by Currie. Our casting is a heavy duty, ductile iron piece that uses the larger JK high pinion 44 gears only. These gears feature larger ring gear than a standard 44 as well as a 29 spline Dana 60 size pinion gear. TJ upper control arm bushing ear is cast onto the housing but can be cut off upon request for custom suspension vehicles.
Tubes are 3" x .375" wall and TJ/YJ/XJ Knuckles are installed and gusseted.
These are completely custom-built units that are made-to-order to each customer's specifications and application. They provide a much stronger assembly than the factory front end in Jeep TJ/YJ/XJ vehicles.
http://www.rwkhaussupply.com/magent...nion-dana-44-front-housing-w-jk-knuckles.html
Robert
RWK Haus Supply
714-875-2414
www.RWKHausSupply.com
From my Site....
Robert
RWK Haus Supply
714-875-2414
