    More Information - Join/Renew
Fox shock info
in4aride
Montrose
Dug all the way back to end of 2013 with no real thread on topic.
2000 XJ 6.5" tons 3 link
Looking at the fox performance series 2.0
Problem is they ship the XJ specific ones with the shaft top like factory has. Need to loop top
Also curious what valving you boys are running on the fox's that seem to work well for you.
TIA
I have fox 2.0s on the station wagon. They do shock things so far. Softer than I would like but so are my springs.
Ive also got some questions here.
I just installed fox 2.0 performance remote resis...
The gas line is awfully short, basically leaves no flexibility to mount the resi anywhere other that where it dangles aside the shock body...can a longer line be installed?
Are these rebuildable and revalvable? (spelling)
i had a short talk today with accu tune off-road and as i understand the performance series isnt as user freindly to rebuild and revalve as the the other fox shocks. he said it requires a couple of special tools that aren't needed to rebuild/ revalve other 2.0 shocks.
i'm on a time crunch to get my rig ready for a sand dune trip and the only 2.0 shocks i could get to my door in time were 2.0 performance series that were intended for a f250 superduty. we'll see how they do next weekend.... i'm optimistic they will do good nice and firm. for the past couple years i ran bilstein 5150s and blew at least one every trip so i'm hoping these will last and if they dont will at least be more cost effective than buying replacements.
i ended up with shaft top remote res up front and regular eye non res rear both about 11.5" travel for about $475 for all four off amazon. i feel like i got them at a throw away price if they suck. then i'll bite the bullet and get the real deal
I got Fox Performance shocks for my wrangler. Near as I can tell, the difference between the standard Fox 2.0 and the performance series is the lack of a standard nitrogen change port. If you don't plan on doing your own service, it doesn't matter. If you think at any point in the future you want to revalve, replace seals, or just recharge the shock yourself without sending it off for service, get the full-on Fox 2.0. Currently Fox charges 50.00/ shock to service.
Edit: for the record, if I did it again, I'd spend the extra money and get the full on version w service ports.
Fwiw I ordered their 'generic' 2.0's with the lengths I needed. The valving is set for more of a light truck vs xj. Rides great. Way better at higher speeds, can be a bit stiff in the neighborhood or mall. But otherwise happy with them thus far.
Hello everyone, I run on my Xj Fox 2.0 By-Pass up front and RR on the back, they are the performance series, more than happy with them, they are a bit stiff on the street but ones you go off road they perform superb!! had them for almost 5 years now and the only thing I have done to them is recharge them with nitro.
If I had to do my Xj again I would buy the same Fox I have now. Expensive at first but they pay for ones you speed up to 80 Mph off road and feel total control.
