Something NEW!
Dan Fredrickson
Sacramento, CA
High Clearance Steering at its Best!
Time to finally replace that old, problem Jeep steering? Personally I can't think of any reason Jeep wouldn't have replaced it years ago. Perhaps the accountants were at the wheel and they kept using that inverted T steering to save the cost of changing it to something better!
Jeep XJ, TJ, LJ, ZJ & MJ Y Link 1 Ton HighClearance Steering Kit
Description
We have been manufacturing steering kits and components for many many years. Throughout that time we have been repeatedly asked to build a bolt in kit for XJ, MJ, TJ, LJ and ZJ.
The Ruffstuff Jeep heavy duty steering kit is the result and here are the features that make it stand out as the strongest and most durable while keeping the price fair. One of the biggest problems people have faced over the years when moving to larger tires and lifts are dramatically increased instances of bump steer/roll steer and potentially death wobble. When using the factory T link steering a compression will cause a toe out situation immediately followed as the vehicle unweights by an extreme toe in situation. Using a complete tie rod as you do with a Y Link you eliminate the constant toe in/toe out motion caused by the Inverted T design itself. That motion itself essentially is what death wobble is (constant toe in/toe out movement).
How do we eliminate tie rod roll? We have been making the item we call “The Cure” since 2014 with great results, it really does help with many steering issues. For our new steering kits we have a new model cure for the greater flexibility required for a high clearance steering. This “New Cure” does not replace the old cure. The New Cure can be used under the tie rod ends at the knuckles, combined with one at the Y Link connection greatly lessens tie rod roll. Tie rod roll can also contribute to death wobble, this is why our “cure” is such an important piece of this kit.
This is a bolt in replacement for factory steering on vehicles with up to a 4” lift. This will work up to 6” of lift with a drop pitman arm and extended track bar, however, you will need to increase the knuckle taper to account for the much stronger ¾” taper vs the stock ⅝” taper on the pitman arm and knuckles.
All tubing included for both the tie rod and draglink are 1020 1.5” x .250 wall DOM. The large diameter and thickness of the tubing and the forged 1 ton tie rods make these the strongest steering kits available.
The tubing is cut, bent and welded here in our shop by professional American welders. Our fabricators constantly challenge themselves to be the best and are known for extreme quality work.
Please call us with any questions. BTW, we've had these on 2 XJ's and 2 TJ's for the last 3 months testing them and they are great!
